which underseal?
iv got a mk2 project car atm and its not far off needing the underseal redoing, the cars going to be white, and I've set my heart on black underseal, to contrast, cas basically that will be the theme throughout the car
the wheel arches will need doing too as I've rolled the arches
i was thinking hammerite underbody seal but apparantly that stays wet?
is there any out there that dont?
as id ont fancy getting under the car and getting my arms or whatever covered init
cheers for any suggestions guys :)
  • Replies 16
  • Views 2.1k
theres plenty of stonechip sprays that dry hard and can be overpainted if req...or they come in black too
either aerosols or 1ltr shutz cans that you spray on with a gun
only prob is most dry up a bit chalky looking after a while , id paint over it with something like rustoleum to seal it and make washing easier
that hammerite stuff is the nuts for stuff you cant see...warm it up after and it melts into all the seams etc
Stonechip is good stuff :thumbsup:
hmm shutz sounds good and comes in black too
you just buy the cannister and gun seperate use the cannister then chuck it I'm gathering?
this the stuff you mean...
http://cgi.ebay.co.uk/3M-Black-Body-Shutz-...id=p3286.c0.m14
i had the shutz stuff BUT the gun constantly clogs, i just use the stone chip and paint protection stuff from frost, or halfords I've noticed do a black or white smooth spray underside spray. i got some to try it out and its fairly strong stuff!
and could this work for the arches as i wouldnt really want the rippled look,
http://cgi.ebay.co.uk/1Ltr-Can-Black-Stone...id=p3286.c0.m14
and could possibly be painted over in black hammerite? or wuld that that just come off?
hi mate do you have a link to that?
I would use POR15 from frost.co.uk rather than Hammerite, much more hard wearing. Available in lots of colours too. The main thing is to strip all the old underseal off as it can just act as a water trap once it gets old, cracks, peels etc... It's a horrible, time consuming, messy job to do though. Especially if your work place is the garage floor with car on axle stands. You will no doubt uncover rusty areas that either need wire brushing down to clean metal or in worse cases, cutting out and fresh metal welding in. Then paint the whole bottom of the car either in normal aerosol paint or (probably a lot better) POR15. Then apply underseal over the top of that.
so as i get it atm
get..
POR15
and then shutz
hayesey i knw what you mean about getting the old stuff off, and the car is on axle styands so yeah no the funnest of jobs but hey ho has to be done lol
that's what I'd do yeah.
cool sounds like a plan to me lol
probably best to get silver or grey POR15 easier to see where I've sprayed when it comes to applyin the black shutz
could i then go over the shutz with hammerite or POR15 in the wheel arches so that theyd be more gloss
sorry for all the questions lol
this website has some good info: http://www.rust.co.uk
I've just done this on mine and its a really horrible messy job! i ended up going down the route of using Dinitrol products as becuase of the welding that had already been done, the fact i was on axle stands in the garage, and the generally scabbyness of some areas it wasn't possible to remove every single scrap of old grud under there which you really need to do to POR15 properly so i just got off as much as i could with a steam cleaner, GUNK and a wire brush attachment on the drill, then rustproofed, sprayed on clear waxoil then covered with Dinitrol 4941 both of which are a bit of a git to spray as you need to keep them really warm and have to keep stopping to warm up the gun every 5 mins so it takes ages! still need to do another top coat on mine but it looks really good and hopefully lasts for a good long time!, still need to POR15 the inside of the floorpan to finish the job.
cheers for that liz I've emailed them and explained what i want
in an effort for some help so hopefully they will get back me to me with a good list :)
they told me about using the epoxy stuff which looked really good, but i'd got impatient about getting mine done in time to take to the polo show so already ordered the dinitrol stuff :lol: probably would have gone with that if id given myself more time but seeing as i had no engine, suspension or interior in thought that was more important at that time.. :-D the basic principal is you need to treat the rust, then put something else on top of that before you use any kind of underseal stuff, putting underseal straight onto just treated rust isn't really good enough. i'd waxoiled before and its ok but you have to keep redoing it every couple of years, and as much as i love my car i'm not a massive fan of undersealing especially with a brush, plus finding a few rusty spots festering underneath wasn't convincing.
Schutz is good, but as everyone has said it is shit for spraying over! When I did the spray job on my 1965 split pick up (which I sold :-( ), I used Hammerite under the wheel arches and I saw my pick up recently (after 2 winters) and it was superb still!!!!
shutz dont dry mate
you want stonechip if you ever want it to dry...then paint over it if you want to
