petrol dial
just wondering on the petrol dial do all four 'sections' hold the same amount of petrol? if u get what i mean :S
bit random its just that from a full tank to 3/4 seems to go alot quicker than 1/4 to empty!
cheers
rich
  • Views 1.5k
It varies from car to car,but generally no.
And neither is the point of empty always perfectly calibrated either. It's really a case of getting to know your gauge.
Mikey hit the nail on the head there :)
Petrol tanks are not a uniform shape and as the fuel sender is normally just a potentiometer with a lever and float all most gauges show is the distance from the top of the tank, things get more entertaining when you consider the float often follows an arc rather than a vertical path, therefore the lower the fuel level the more the float moves for a given drop in fuel (as a larger horizontal component is required relative to the vertical drop).
As always!!!
hm interesting cheers guys :)
