6n 1.6GL....
Just picked mine up today, would anyone care to shed some light on the good/bad points about them..
One thing i noticed, 75bhp is a let down for a 1.6 like
having trouble getting pics up will try later tonight
  • Views 1.2k
I've had mine 4 around 3 mnths and had a few small problems which most polo owners have,window reg,throttle body ect but rate them as there good cars,sure the engine could do with a little more power but if the car is in good condition then you can up the power with some mods,cam exhaust map ect or do what I'm planning and put a donor engine in
spot on mate cheers, sounds like a plan...
for 500quid...how much am i going to improve the bhp its kicking out?
what would be the first steps...apart from a decent induction kit ha
£500 will get you another 75bhp if you spend it right (nitrous with a progressive controller). Stay away from induction kits (my 16v had one when I got it and ditching it improved matters no end)
I wouldnt use nitrous on a 1.6, they have a long stroke so the bottom ends can die quite easily. (Apparently, mine hasn't died yet but its low miles)
If you really want to give it a kick up the arse do what i have done,, mk3 GT injection on it. Search for my thread (1.6 GT) That in it self gives about 20bhp more, with an exhaust and chip it will be 110bhp+
Theres also bike carbs, do a search theres alot on the subject
And the easiest will be just to put an exhaust on, chip ect and maybe get 10bhp more.
Bike carbs are a big step backwards, carbs are nowhere near as good as fuel injection. By there very nature carbs can only be tuned for a very limited rev range.
There is nothing wrong with nitrous on long stroke engines as long as it's set up right but that's true for short stroke engines as well. You are looking to increase the BMEP without increasing the peak cylinder pressure the problems come with people who just bolt a bottle on and expect to get a 100% power boost with a dry kit, with stock ignition timing but they will blow up there engine one way or another.
If you go down the nitrous route it can get addictive, but a lot of fun. Just make sure you get it set up properly, its worth it in the long run. But it will hit you in the wallet after a while
I'm thinking of it for the 1.8T, but possibly only running small jets and a pressure switch as anti-lag. Or I could get greedy and look for 350bhp with it. :badgrin:
