What prep do i need to do before spraying
What prep do i need to do before painting a front wing and bumpers (6n if that helps), or can i just paint over the original paintwork
Edited by deanwt
  • Views 1.2k
Bump
if its good original paintwork , sand it with 800 wet n dry with some soapy water
sand until all the paint has lost all its shine, make sure you get the edges and swage lines etc
degrease and paint it..
Cheers, will make a start tomorrow. Odviously wanted to get a little help beforehand.
I dont suppose you would knw how to spray bumpers, would they need sanding down too?
what is it? old painted bumper , new one or what
if its plastic clean clean clean as there usually loaded with silicone unless its a painted bumper.
as for paint prep if the existing paint is good then scotch and spray away :)
