Is there an easy / good way to remove texture?
Hi,
I have a set of 6n2 door strips that are textured which I want to colourcode.
I'm debating whether to just paint over the textured surface or find a way of smoothing it off before painting.
Any ideas?
  • Views 990
power sand them, plastic prime (surface will still be bobbly) sand again by hand and the bobbles should start to go, repeat if required.
the other way is to use high build plastic primer or skim with plastic filler then flat back to a smooth finish
Cheers Jon,
Would you say the finish will last?
I should have got colour coded ones and re-painted them in my colour oh well spent out on them now :-(
so long as you use plastic primer and you make sure the plastic is 100 % free of dirt then yes
