vagcom
got one in the post from ebay,any good?is there a big fat red button that makes my 6n run like a dream or confusing data to maul over?
  • Replies 15
  • Views 1.5k
From what i know, you run it via a laptop or computor, to your car, and it finds a fixes fault codes.
I got mine done at Edition, the guy connected his laptop and cleared a lambda sensor fault my 6n had.
It wont instantly make your car run perfect, but there could be faults that you're not aware of that could be affecting your car, or an electrical problem, that it can locate and fix.
u got alink to the one you bought?
is it just a code reader?
http://www.vagcom.co.uk/
Just a program it seems..
If all your wnting to do is clear codes you can get a little box that does it. I have one, used to live in my boot but I dunno where its gone now!
With the full program I'm lead to believe you can change things around. Like add that thing were it locks the doors if you do over 10mph or something.
VAG-COM can also operate functions and items on the car using it’s output tests function. For example, the EGR valve can be opened, the fuel pump relay turned on, the windows can be opened or closed, you can operate the ABS pump. The list of items you can control is almost endless.
:nod:
well you need to go to the vagcom website and download the software, either the free version (which only decodes first few fault codes and can't do more complicated things) or pay about £100 for the full version.
Just get the free one first and try it out.
It wont "fix" your car for you, it'll tell you any logged fault codes which sometimes helps with diagnosing problems so you know what needs fixing. The usual thing to do is read the fault codes, reset them, drive the car for a bit and see which codes (if any) re-appear.
You can also use it to display and graph values the ECU is seeing from various engine sensors, which if you know what you're looking for is more useful than reading fault codes.
will that cable work with the mark 5's?
I have an Ebay cable and it talks fine to 6N and my Ibiza but not to my 6N2 (not given it a go on the G40 and using it on the Mk2 isn't going to happen ;) )
Received mine today, works fine with my GTI. Just wondered would it be worth the $99 getting the full version. Any interesting things you can do to the GTI with it?
not really mate
cracked the software anyway(absolute bitch to do) so got a good deal :badgrin:
fancy sendin me it nod?
check your PM's mate
just got my vagcom,works ok but showing no faults???even tho car is not right at all.used the measuring blocks,temp is at 90 odd then suddenly shows at 45?had a new temp switch and thermostat so doubt it.air temp well over at 90-97?should be at 70 according to the highlighet parameters.throttle position at idle over its parameters?any ideas
