mk2 front valance
just wanted to know where u can buy a front valance for a mk2 ?
  • Replies 9
  • Views 3.4k
was one on ebay last time i looked...just the lower bit
Go down to your nearest Eurocarparts centre.
According to their website they have them in stock and at £10.75 + vat they have got to be worth a try.
However, be aware that fitting a lower front valance on a MK2 isn't easy, unless you are used to doing bodywork of course. Ideally, you'll need to remove both wings and have access to a spot weld drill, there are lots of welds!
ok dude il check them out
the lower valance isnt structural is it?
could trim off the dented/rusted lower bit and rivet on a new panel , they only supply the lower bit anyway
The lower valance certainly is structural. The lower valance consists of not just the bit you see under the bumper, but everything from the bottom of the grill downwards. This includes the inner panel that supports the radiator and is welded to the inner wings and chassis legs. This is the reason that the mk2 Polo is stronger than the mk3, it actually has a heavily profiled panel welded in to hold the chassis legs together as opposed to the frankly rather pathetic bolt on one the mk3 has.
However, if the rust is just confined to the outer skin then you could just cut out the rusty part and replace with a better section from a scrap car. But FFS, don't pop rivet it in - get it welded in properly!
well its the upper part thats damaged on my car just bellow the light iv tried to re shaped it , didnt know if u could get the whole front valance or not n thought might av been easier then repairing my damaged 1.
ebay valance
thats the one i was talking about...more of a repair panel , is that not below all the welded bits ? i didnt mean pop rivet on the whole front panel
anyway...no good to polory as its not the whole panel
for the hassle involved repalcing that piece youve dented , id strip the grille and bumper and try to straighten it best you can then fill and paint it , looks like its the bumper thats bent down more than the panel i recon it'd straighten up okay
Edited by steveo3002
yeh think thats probly the better idea strip it down n repair it
  • 3 months later...
random thread hyjack but whats the splitter off? mk1 golf?
