mk2 door handle
I hate this cold weather, there's my squealing speedo, and since Wednesday the driver side door handle doesn't work.
Door was frozen against the rubber. Squeezing in the trigger and pulling very hard on the handle it opened, but next time I tried to get back in it was tougher still.
And the third time, I had started the engine while I scraped ice off the windows, keys in the ignition, demister on, engine running, closed the door to keep it warm ...
...oops... :shock:
I thought it might run for a day on tickover till the petrol ran out, and had a few crazy ideas of pulling off the main ignition lead or fuel pipe from underneath or working out how I could manage to get home to get the spare keys. Finally yanked it open really sharply. My taekwondo tarining is good for something.
Since then I've been unlocking the passenger door, reaching across and opening the driver's door from the inside.
I'm really tempted to fit remote control central locking kit from Maplin, but it's bound to go wrong.
So off to the scrappy to find a replacement door handle. I imagine a lever connected to the trigger is broken.
Golf handles look just the same.
But Haynes is silent about replacing the lock barrel.
Is it easy or just fiddly?
  • Views 1.3k
Edited by a.polo.13
Abit of bad luck there m8. sounds like the sping has broken, like you sayed at the trigger. but not a hard job good luck
Nightmare mate, I've had the squealing speedo and have been very close to shutting in my only key into the car. I've got a full set of locks with two keys which I keep meaning to fit but some other car grief always crops up.
Anyway as far as I know this is very fixable just swapping barrels.
super easy to swap the barrels over...1 screw lol , mind the barrels dont fall apart when you pop em out , they shouldnt but best done over a clean table just incase
are all your locks (except petrol ) on the same key? you can file the tumblers to make it all work on one key if not
golf 2 rears fit as well if you want to delock it and get the central locking kit
i took my passenger lock mechanism completeley to bits to lubricate it all where it seized and refused to let people in the car, lever pulls back half way but doesnt do anything. its not that complicated once you get your head around what bits do what, the handle and lock barrel are simple enough to figure out without the haynes.
disconnect the bloody speedo, who needs it, if you have a rev counter and know what gear you are in you can be close enough to legal.
I ran like that for 6 weeks, including driving 1500 miles down to kent and back lol
