13" on a 6n....
rang rimstyle today and they told me i couldnt have 13" wheels (ATS classic) to be precise because of the brake clearence... however there is clearly cars on this forum that are running 13"... do they fit ok????
  • Views 1.4k
i got my 13inch classics from rim style i have to run the fronts with a 5mm spacer to stop them catching the caliper, so yes hes kind of right... however mines an 8v and yours is a 16v. i beleiver the 16v's have bigger calipers, is that correct?
I'm not too sure wether they do or not :paranoid:... although I'm curious to know coz I'm fancying some 13" and would be a bit poo if i couldnt have them....
Sorry to say but you won't get 13's to clear valver brakes without mahoosive spacers, which I wouldn't recommend trying
:-( okie dokie cheers for that....glad i didnt go ahead and order them :lol:
I'm running 13X8 Alley cat's on my Polo, it's a 95 1.6CL with solid disks, i had to grind a bit off of the width on the caliper to clear the inner face of the wheels but diameter wise there is loads of clearance.
I have dropped it about 20mm more since taking these pics.
that looks cool but you need to be super low to pull off 13's on these :)
cheaper then spacers i guess. I thought nothing of it when i put mine on, and then i attempted to spin the wheel, ha. Winter wheels will do for now.
