1.2 Polo won't start (2002) Where is the crankshaft sensor?
Hi everyone.. Someone on another forum suggested I tried on here for help, so hello first of all.
Where abouts is the crankshaft sensor located? It's an 02 1.2 Polo. It wouldn't start this morning.. then started, made a bit of noise (I thought it needed oil) and then died.. Won't go again now. It turns over fine, but won't fire.. Sounds a little bit dodgy on turnover, but that might just be as it's only got 3 cylinders? I thought it could be the cambelt snapping, but it's got a chain and it looks fine.
It's my sisters car and she needs it pretty urgently.
Anyone know where the crankshaft sensor is or have any other suggestions?
Many thanks.
  • Views 1.6k
Many thanks.
sorted.. you can remove if you wish.
The timing chain isn't prone to problems, its the timing chain tensioner that causes the chain to slip a notch or two...enough to disable your engine but not enough to cause any damage.
