MK3 GOLF RECARO LEATHER SEATS FIT POLO 6N2 GTI
Hey,
I'm new to club polo so fogive me if I'm asking a stupid question.
Been going through the forum and have been getting mixed opinions on the subject. :?
I can get my hands on a set of MK3 GOLF COLOUR CONCEPT RECARO LEATHER SEATS. Would these fit easily into my 6n2 polo gti?
After reading through the forum i assume that the front would fit straight in and the rear would with a bit of work. Am i right?
How about the door cards?
Also would golf mk2 interior fit a polo 6n2?
Edited by ash2die4
  • 2 years later...
  • Views 3.9k
my understanding, is that the rear seats, the single seat part, will fit in fine, but the right and middle seat wont, they will be slightly to wide. could be wrong though
What it is that golfs are a wider car than the polo's so it requires a very small amount of work.....
The fronts fit straight in no problem.
What you have to do with the the rears is.... the base of the seat fits straight in its only the back part that you lean on has to be changed.
First make sure that your polo has a split rear bench the same as these golf recaros, then if you look around the sides and back of that back bench there are clips you basically unlcip the fabric off your original polo back bench and then do the same with the golf ones then swap over easy as that.
Think theres a thread in the FAQ how to do it?
