G40 Turbo conversion kit
I've decided to sell the G40 Turbo engine off for spares. Got a full turbo conversion kit if anyones interested. Most of the pipework I've made myself. Worked really well on the car. Heres a list of parts:
Custom PSD turbo chip (G40 injectors/ 14psi max)
Mk4 AEX exhaust manifold with laser-cut adaptor plate and TIG welded turbo flange
Garrett T25 Turbo (and a spare if you want it)
Heat wrapped custom 2.5" downpipe (with thread for lambda probe)
2.5" exhaust system with single back box
Turbo- to - intercooler pipe
Modified Sierra Cosworth 4x4 intercooler with mounting brackets.
2.5" boost pipe from intercooler to plastic boost pipe
Plastic boost pipe
Aluminium 'T' piece for dump valve
Dump Valve
Custom throttle body elbow
2x coolant 'T' pieces for turbo coolant lines
Turbo coolant pipes with banjo bolts
'Hose Solutions' braided turbo oil feed pipe (including banjo bolts)
16mm turbo oil drain pipe
Nearly new engine sump with TIG welded fitting for turbo oil return.
I'll get som pics up of the parts during the week if anyone's interested.
I'm after £600 ono
Edited by tomwood_uk
  • Views 771
alright mate can i ask why your selling it ? i was thinking of doing a turbo conv on my eatoned g40
steven
I've had fueling problems and melted a piston, cant afford to rebuild the engine again so I've decided to cut my losses.
I've got loads of other G40 parts aswell i anyones interested.
ill have your oil feed an parts an your sump if you sell seperate???
I'd rather sell all the parts togethor to be honest. If they don't sell we might be able to sort something out.
Forget to mention theres a one-off PSD turbo chip to go with this (mapped for 14psi and standard G40 injectors). This cost me £120 alone.
Few pics guys:
Will take reasonable offers on this.
