Random Polo Problem
Hi all,
Got a slight problem with my polo, wonder if anyone can help.
If I have the polo lights on, the dashboard and radio light up - as they should. However, if I turn the engine off, or am braking, the internal lights will flash on and off. Headlights stay on regardless. It happens more frequently when the engine is turned off, with the key in the ignition. Does anyone know what is going on?
Thanks in advance!
  • Views 685
Popular Days
I'm not technical at all, but if you think about it, it might be something to do with the battery running low,
like when you brake your losing engine revs, and obviously when you turn it off you dont have any, and i think in some way the engines motion charges the battery while you drive, not sure of this though...
it must be a power loss thing though, otherwise they would work on or off if it was a loose wire or something.... that happened on my heater light, and if i want it to go on, i have to bang it on the side lol and it works...
