Polo 16v on a Track day
Hi,
I'm looking to do a few track days with my valver, but i'm just wondering how capable they are at handling track abuse. I will have it lowered by the time i track it so i know what to expect with handling. My main worry is the gearbox. Also should i think about upgrading the brakes?
Any help will be greatly appreciated
Neil
  • Replies 44
  • Views 4.1k
II wouldn't worry too much about upgrading things just have a check that everything is in order. Check that you pads and disks are in good condition and have plenty of life left. One think I would recommend though is an oil and fluid change. Use some good quality oil change the brake fluid, especially if it hasn't been done in the last 12 months, and change the coolant. Don't go over board with the anti-freeze stuff though as if you do have a coolant leak it can make the track really slippery and dangerous for other drivers.
As long as the car is in good condition there isn't much to worry about but I can't comment on any specific issues with the mk4 as I have never had one.
See how the car copes on this track day and then upgrade the parts you need improving or when the standard parts wear out.
Edited by max_crox
i would say they will be fine, how about uprated ARB's and new bushes etc.
The brakes would probally be a good idea if you have problems braking with the standard ones. maybe just put some different pads on. I'm sure Foxie has taken his on the track at some point (seem to remember reading it in a topic on here ages ago). sure somebody with better knowledge will be here to advise you soon! ;)
II wouldn't worry too much about upgrading things just have a check that everything is in order. Check that you pads and disks are in good condition and have plenty of life left. One think I would be tempted to do is to renew the brake fluid if it hasn't been done in the last 12 months.
Thanks for the fast reply mate. I do need to renew the brake fluid. Pedal feels a bit spongy. Pads were changed two weeks ago and disks are in good nick, hopefully won't have many breaking problems.
Thanks for the reply mate, do they do uprated ARB's for the 6n? And do you know if the poly bushes are a good investment over standard ones?
Neil
Iv heard that the car feels a lot better with new bushes. Try going for a good make though when you buy them. think theres a company called Poly something that do them.
I'm sure the valvers came with ARB's as standard but they dont have an under the bonnet one that bolts to the top of the struts. however I've heard stories that these dont make a difference anyway. Certainly be worth stripping the car out back seats wise and investing in some good tyres.
Also when lowering i have heard stories that if you lower the cars centre of gravity too much then it will handle even worse.
Never been on a track in a Polo in my life :lol:
Hmmmm, remember it being a black polo with dished wheels, must of been somebody on here? sorry bud!
that was probably jez, he took his round donnington a couple of years ago.
make sure your brakes are in good order and you have good pads, they will take an absolute hammering. Also make sure you've got some decent sticky tyres on, you'll be all over the place on cheapo budget tyres.
What suspension kit are you going for? if you are getting coilovers and don't have time/money to get it corner weighted and it's a budget kit, set it up with some arse down and you might stand a chance at decent handling. Couple of degrees negative camber up front is always good too.
arse down? as in back of the car lower than the front?
Yeah, probably the best thing I ever did on the Golf, because off the shelf budget coilover kits always seem to have the front too stiff, and the rear too soft, so you get nothing but understeer.
oh so you mean make the rear stiffer not lower. yeah well that's OK.
Well I did mean slightly lower at the back yes because it's the only way you can effectively make them stiffer without resorting to a stiffer rear ARB.
i'll be getting springs and shocks as apose to coilies. Prefer the ride on springs and shocks. I'll be going 60/60mm like i had on my last polo, seemed to be the perfect combo of looks, ride and praticality.
Thanks for all the replies, been a big help
cheers
Neil
oh and the diff will go bang
can you explain this please
diff wont take the abuse unless its reasonably new, 16v puts nough torque thru the diff as standard as the diff is a dire very very weak component in you are g'box.
Couple it with full throttle, max torque, heavy camber high revs i can hear it seperating now, it will literally explode, well it will if you can drive it very well :)
oh ok, have you had an experience of this before? and is the diff cheap to replace?
cheers
Neil
cheers
Neil
depends what you have done, either way its a box out affair, the standard diff may as well be made of chocolate, if the diff doesn't explode it will be because the input shaft goes bang first either way at a pace on track it will take all the other internals with it
err no a diff is not cheap to replace. however i dont believe you will kill one that fast, i've done a load of road rallies, autotests etc that are all very heavy on diffs and never broke one, and i'm using a hybrid of a 16v box and a gt box.
regarding the nose up arse down thing, it does work, i run mine as low on the back as i can get away with. It only works if you have the right spring rates though, it means you can dial out the unpredictable ness of list off oversteer just enough to stop understeer
how quick its killed is dependant on how good you are on track and how good the diff and box are to start with, i.e exiting an apex too slow on a negative camber in the wrong gear and hard on the gas can take it out instantly......all depends on the ingredients of the moment tbh
g40s put a lot more torque through a standard diff and deliver it more violently than a mk4 16v too and they don't blow up all the time. If you've got enough oil in the gearbox should be no problem, unless it's already borderline fucked!
yeh not being funny, i am quite hard on gearboxes and never had a diff fail.
I didn't think that it was Mk4s that had a problem with weak gear boxes. I Thought that was the mk5.
I really doubt you will have any problems. As long as the car has been looked after there is no reason to think it will suddenly fall apart and break.
Just give it a oil and fluid change and then go and have fun. :)
What tracks are you looking at doing?
