My mk4 is falling apart
Okay i know my polo is on its last legs but i need to make sure it can keep me running till i can afford a new car, I've had a it a few years and so far I've being hit n run on the rear passenger wing my drivers side window has snapped of the mototr hinges (its a 1.4 cl) the airbag light has come on and now the abs light is stuck on, how much is it usually to repair things like airbag and abs, i think the abs sensors might be dirty but thats about it, already cost me 500 quid to get it thru mot with a new cat being needed and all and now all this has happened, any help would be appreciated!
Pete
edit: its a 1997 R reg, 1.4cl done 116,000 miles and drives like a turd
Edited by ptbpolo
  • Views 1.3k
my ABS light came on after having work done at a garage... so being a sensible fellow, i tanked it down the road and slammed the brakes on, still working, so its just something come loose, it comes back on occasionally, and my friends car is 52 plate 1.4 and his has like 4 lights on, which decide randomly to come on, and his still drives fine....
my advice, run it into the ground, VWs are pretty hardy. if it still runs safely, as in your brakes, tyres, and all sorts of important stuff is fine, it should be ok... if your airbag light is on, i wouldnt know what to do about that, unless your car has been in a crash? try get as much free advice out of garages as possible, i go round a few and ask em what they think... and ask your friends, i always go to them before garages!
i'd be lost without my mates knowledge of cars - garages suck!
I'm the only mk4 owner out of my mates, the airbag light only came on about 2 months prior to my post and the abs has being going on and off since i owned the car, just thinking about my mot in feb-march time :(
everything works fine tho, kinda. revs are a bit off but thats crap in my throttle body and the aux belt makes a wine but apart from that runs fine and the abs still works, so I'm guessing sensors.
next question, i can only open my car using cl from the passenger side and can only lock it using the drivers side, i know one pumps gone but dont really wanna replace them both!
Edited by ptbpolo
Hello and welcome to the site. You may have more luck if you post in the technical section rather than 'chat'!
Right your shopping list of problems:
1. AIRBAG light - I'm afraid that this will need someone with a scan tool. It may be an intermittent fault and the codes clearing or something more sinister. As long as the light is on then the AIRBAG system will not deploy!
2. ABS light - may be a dirty sensor as you quite correctly state. Again needs a fault code scan to see actually what is going on. The car can actually tell you which sensor is playing up. Replacements are quite cheap see ebay et al £15 or so.
3. Central locking - there is only ONE pump. It's in the boot next to the first aid kit. The fact that using one side to lock/unlock and the other will work too (is that correct?) suggests that the pump is ok and the lock may be at fault. These locks are prone to the eccentric and paddle breaking - please do a search for this in the technical forum. Replacement eccentrics may only cost £10 for both sides but you need to take the locks out and have a look!
4. Window broken. Wait until a sunny day and then take the door card off - you may be able to bodge a cheap fix else replace with a second hand unit.
5. Erratic or rough revs - cheap enough to do a throttle body washout yourself. Search in technical section. Can of Carb cleaner £5 from Halfords.
The car is not written off yet!I would suggest that a £15 Haynes manual, socket set and torx screwdriver set are prudent investments in your case.
PoloD.
Edited by PoloD
I'm with PoloD, there is loads of life left in your motor yet, just needs a weekend spent on it
Yeah it's not all bad Pete. 116k and driving like a turd is about right!
Back in 1999, I test drove 3 different 1.4 CL's, all with under 40k and came to the conclusion that they drove like a turd too! :lol:
lmao breadman
