What to look for when buying a car with a conversion
Hi All
As above just wanted to no what to look out for if buying a car that has already had a conversion done, Is there any specific thing's i should look out for i.e who the conversion was done by, how long ago, what was carried out etc etc. If anyone can shed any light it would be appreciated.
Omz
  • Views 904
Depends on the conversion that was done, if it was a 1.0 6n for example then a valver engine had been dropped into it then you will need to make sure the extra mount was put on properly and the brakes and running gear were upgraded to the valver ones.
You seem to have the basics covered though, just have a good look round the car and check every little detail that you think of that should be or is different from standard.
after having my abd/gt i wouldnt buy a conversion again unless done by a pro with documentation
