JBL Subs and Amp
Two (2) JBL (CS12) Subs in double black carpet box
12" sub
Peak Power Handling- 500W
RMS Power Handling- 125W
Frequency Response- 38Hz – 800Hz
Sensitivity (2.83V/1m)- 92dB
Impedance- 4 ohms
Cut-out Diameter- 277mm
Mounting Depth- 127mm Thiele and Small Parameters
Revc- 3.58 ohms
VAS- 144L
Qts- 0.39
Fs- 24.7Hz
Qes- 0.41
Qms- 7.34
Mms- 119g
Levc- 2.3mH
JBL Car Audio: 4ch Amplifier - GTO-75.4
104 watts RMS x 4 channel at 4 ohms
284 watts RMS x 2 channel at 4 ohms
3 channel mode: 2 x 104W RMS + 284W RMS for sub
Ratings at 14.4V supply
Variable cross-over. Variable Bass Boost.
Speaker Level Input
Overload protection
Dimensions (H x W x D): 2-3/8" x 15-1/8" x 12-5/16"
£50 for the subs + box
£65 for the Amp
Collection only from Huddersfield or Dewsbury, West Yorkshire
J
  • Views 397
Amp now sold ...... make me an offer for the subs :biggrin:
Edited by JBOB
Where abouts are you?
Nr Huddersfield
