track day polo gt
Hi All
just had my car stolen and am looking at getting a polo gt 1.3 and wondered what the ability is ogf these cars? i am planning on doing a few track days ect and then use it daily.
does anyone else track these cars?
  • Replies 30
  • Views 2.7k
Hi All
They aren't bad.. :) Granted they are not the most powerful cars or the best handling but after a few tweaks they can be made into really fun track cars. Mines not a Mk3 but I have a GT engine in my Mk2 and it a real hoot to drive and through twisty stuff can keep up with/overtake a lot of more expensive stuff. There are more than a few track day Mk2/3s out there so you won't be alone :)
Top speed is never going to be great but getting to 70mph is really rather quick for what it is. You can get 85bhp out of the engine for a small amount of money and 100bhp is relatively easy to get to if you want to spend a bit more and stripping out the car will bring it down to the 800kg range. There are a few easy choices for engine conversions if you want to get you hands dirty.
So over all not bad little things..
considering a mk3 is 800kg standard, stripping it out can make it alot lighter!
Even better then. I thought they were about 830kg and I know stripping out the rear and spare is about 30kg hence where I got my number.
Out of interest do you know what yours weighs?
i thought the spec book listed them as 720kgs?
Well Haynes has the weight for a mk2 85on as 730 to 770kg and a mk3 as 765 to 830kg
830kg is G40, slightly heavier with charger and associated pipe work, intercooler trim etc.
mine last time it was weighed was 720kg although i've stripped it more since then :lol: i recon i can get it under 700kg quite easily
i'm aiming for 660kgs with a full cage, subframe conversion and G4T lump.
mine has a dash and 2 front seats in now, drivers doorcard (needed the storage pocket till after this weekend)and headlining due out.
also gonna be hacking up a tailgate and the doors, and getting rid of some of the glass and hole-sawing the c-pillars an getting rid of spare wheel well, and rear seat base metalwork(unless i use it to support internal fuel tank)
its an acheivable target, as i know of a mk1 golf weighing 650kgs with a 1.816v on throttle bodies and a full cage, and there's no way a polo with a 1.3 turbo an cage is gonna be that hard to get light...
Mk1 Golfs in general weigh less than Mk3 Polos though
I think you'll struggle with 660 kg without spending stupid money.
edited because I can't spell
Edited by tobyk
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
I get the feeling you think its an unlikely target Chris?!! :lol:
I reckon a mk3 GT is pretty good value for a track day/road car. They are durable little cars, with very strong engines that won't mind a bit of high revs/abuse.
The handling and brakes aren't a strong point, but with relatively little money can be improved a lot.
Edited by breadman
orly?
dont think its possible ey?
i think there is LOADS of places excess metal can be lost with a polo, i dont think you quite realise just how much is gonna be cut/drilled away...
Edited by Jackblack
Even with a cage you still need a considerable amount of metal in the shell unless you are spaceframing it!
mmmmm not really if i get the cage i want (full turret-turret job, fully triangulated seam welded in places) then i pretty much wont need anything past the rear turrets, so most of that can go, no glass, no inner front wings, fiberglass replacement wings, bonnet, maybe doors, but not sure how practicable they are...
few other places than can be abused, plus no internal sound deadening, anything that can be made lighter, will.
i definately think its achieveable.
My cage weighs more than most things I have stripped.
There is nothing to be saved from a door. I tried it an realised that having a shave would save more weight.
Not alot of meat to be had out the c-pillars [again I have had a look]
@750kg with ~200bhp gives you a lovely power to weight ratio.
660 with 200 gives a better one!
and every little helps!
cage will weigh a fiar bit more, but will mean other areas can be almost nonexistant, plus it'll stiffen it up LOADS.
The money your going to spend building a 300 bhp/tonne polo you can buy a real car
Since you want to get to 660 [which is possible] then I suggest you start looking for fibreglass pannels as there is no way to safely remove metal to get you down to that weight with a cage.
Buy a mk1 polo
never said i didnt think it was possible. a waste of time, and money more like. why would you want that? you would never be able to d anything with it
Buy a mk1 polo
true.
but "polo turbo" sounds better than "corrado vr6 turbo" when talking to an insurance company.
fiberglass pannels are available from the fatherland, metal doors are free, might as well start with what i got, then work in some fibreglass when i got a cage.
becasue untill the cage an mad lump go in, its just a supalight GT, so fun, cheap to run and insure!
who wouldnt want a 300hp/tonne polo?
think of the giggles you can have with much bigger cars! :badgrin:
if i get the setup right i should have the ultimate giant-killer lil sleeper.
cheap, not when finished.
ugly, yes.
pant-wettingly fast? i hope so...
it goes for its MOT next week, then i crack out the powertools... :badgrin:
surely you juust won't be able to put power down with 300bhp/tonne in a polo
i think it would be utterly pointless. Not like you could use it to any purpose really is it? it would be completely illegal for any sort of british motorsport.
It could be used for track days though.
I would be careful about taking out too much metal as they are not the strongest cars in the world ever anyway. So reinforcement might be needed which might add as much weight as you take out :)
Since the day I bought my G I have spent thousands on the chassis and truth is I am miles away from being where I want.
Put it this way. Poorly mapped and fairly stripped I have never thought to myself 'More power would have got me round that bend faster'
Make the chasis and change the engine. Dont try to build the chassis around the engine like I am doing.
If you are using a car for track days then you don't need to find expensive ways of shedding every last kilo you can. That sort of effort should be reserved for competition cars. By the time you create a monster Polo track car with a cage + high tuned turbo motor you could have perhaps bought something else better or even something that you could compete in (Mk2 Golf GTi championship?)
If I were to start over again I'd have put the big brakes, suspension, 14" wheels, steering wheel on my car as I did...then stripped it out a bit. I'd then have taken it to lots of track days and had a lot of fun with the standard (or lightly fettled) engine. Bit like what giorgio says but that's hind sight...
With the idea of building an engine around a sorted chassis I'd be tempted to get a Civic VTi Saloon (MB6 that looks similar to a Rover 45/400 http://www.tribeca.simpsonstudios.co.uk/me.../mainimage.jpg). For less than £2k you get a slightly detuned Integra Type R engine with 170bhp and a 8500rpm limit, limited slip differential (!), fully independent suspension with front and rear anti-roll bars and suitable brakes with disks all round (similar 282mm to '98 spec. Integra Type R), 15" speedline alloy wheels (mmm decent tyre choice)...it weighs about 1250-1300kg if I remember rightly but it'd be possible to shed so much weight given that it's very comfortable car with a lot of nice extras. Slap on some coil overs and your away. Second hand bits like Integra gearbox + cams + manifold etc. could cheaply raise power and performance a fair bit.
Although all the above goes out the window if you just really want to have an awesome Polo track car...in which case fire on.
Edited by Tav
VWDRC.
plus if i wanted to compete in motorsport i'd be giving group N a crack in something 4wd
hence a full-on cage, not a flimsy bolt-in jobbie...
chassis is first, after the MOT (tomorrow is big work day!) h&R cup kit, 15's, bodywork, re-bushing and subframe conversion, a lick of paint, then i'll try the ABD lark, and enjoy it standard for a while, when i'v got the funds, find a donor with a G, engine dropped off at my preferred builder and shell to be caged at my fave fabricator.
i can insure a stripped-out sorted-chaissis GT, i cant insure an ABF mk2... (mk2 8v's are slow, but abf's go nicely in digipantz cars). no point in getting a high-miler 16v, and no point gutting a good low-miler.
i'm going 15's, with the rear arches sorted out so i can have some sort of suspension travel, g40 brakes with 16v m/c and braided lines (plenty for a gt). i'd like a smart MOMO (none of this chavy lark). will maybe try to find an ABD bottom end before i go G40 hunting, and run it chipped and cammed.
i hear that, but again, insuring it? with the GT i can build it all, and then drop the lump in when i can afford the premium, its not like they are the hardest cars to swap engines in! then all i gotta do is get it mapped up and run in and away i go.
it sounds simple, because polo's ARE simple.
once i get done, and want something bigger, i want 4wd and v6...
good few years away yet, this weekend is brakes, gladerseite ARB's, wheels n tyres, tank and headlights for MOT. after xmas, H&r cup kit, then bodywork and 15's...
cheers for the imput guys!
this isnt an overnight build, hell i cant touch a g40 till next july as i'm still only 20 till then... puls i'll probs get distracted with another mk2 golf...
:lol:
nice to hear some constructive criticisim on here, rather than "no you can't!" 8-)
