Idle speed control?
Hi people! my 8v 6n seems to be idling roughly/juddering a bit and seems to be slower accelerating, so plugged my code reader in and low and behold I had a code!,I had this fault code before and the garage just sprayed some carb cleaner down the throttle body,but this didnt get rid of the code straight away(but did evenutually!),is there a part that might need replacing? is this a common fault?
its got a K&N 57i induction kit fitted (could the oil get in to the throttle body??) should I just throw it in the bin :lol:
  • Views 10k
The DTC refers to {from Wiki}
00533 - Idle Speed Regulation
00533 - Idle Speed Regulation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Bad Fuel Economy
Possible Causes
Air Leak between Mass Air Flow (MAF) Sensor and Engine
Injector(s) faulty
Fuel Pressure Regulator faulty
Throttle Body faulty
Intake Air Filter dirty
Possible Solutions
Perform Throttle Body Adaptation
Check Hoses and Pipes to/between Components
Check Intake Air Filter
Check Fuel Pressure Regulator
Check Exhaust Gas Recirculation (EGR) Valve
Check Injector(s)
I suggest you clean out the throttle body and perform a reset to 'Basic Settings'.
PoloD.
Possible Symptoms
Bad Fuel Economy
Possible Causes
Injector(s) faulty
Possible Solutions
Check Injector(s)
PoloD.
Thanks! I'm going to try cleaning out the throttle body and cleaning the air filter then :-) , but how do I reset the ECU to 'Basic Settings?' do I definatley need to reset it? and how can I stop it coming back?
  • 5 months later...
Same problem, but I hear a hissing sound as soon as I turn the engine off. Should I check the hoses? Which ones should I be looking at?
I'm such a freek i like to send myself messages and funny texts haha I'm sooooo cool ....... you wanna know my name///// its peter pan
  • 3 years later...
soz to bring up an old thread but when it says to do the thotle body adaption whats that then?
