Air Bag Wire Broke On Back Of Wheel
Hi all i have just replaced the indicator on my mk 4 Polo & broke the wire for the airbag which comes out the back of the steering wheel.. Its broke in the connector itself the part which connects the wheel to the car..
Is it fixable as I'm not sure what to do as its a strange type of wire to repair as its flat ???????????
Hope somebody understands what i mean
Matt
pic?
Can it be soldered? Or is it a flimsy ribbon cable, like the ones used in PC's and whatnot?
Edited by euro-derby
yeah its the ones used on pcs ant that ribbon style will try & get a pic up
would the ribbon style wire solder?
flat asin spade connection? possibly cut the sleeving off and crimp a new spade on :D if you fit a aftermarket wheel you can do without anyway :D
If you go carefully, you should be able to solder it back on to the connector. The risk is melting the fine insulation on the ribbon from the heat of the iron. If you use a low powered iron with a fine tip, you should be okay i think.
