new on here interior and body work questions
8-) hi new on here join up a while ago but only just got my polo its a mk4 t reg 99 6n 1.4 8v i think on 17inch momos ha (which will be for sale )
winter is here so my mk1 golf gti sportline cab has been tucked away so needed a winter car hence my polo !
!anyway my polo has a dent in the passenger rear quarter so got to respray the back as bumper needs spraying and boot as well just looking and i could have some fun with smoothing but whats the best look of bumpers on these
delete side strips
got a spare set of polished le castellets off mk1 cab so there going on
any thing else be smoothing you can think of?
will the interior of a 5 door mk5 fit in my car?as mine is horrible at the mo and one in scrap yard near me will any thing else of it fit worth having there are a few golf gti mk3 s in there do these seats fit i know these questions must get asked loads but i am new to polos but it will be cool will do all the work myself
will put some pics up of polo and golf ha if any one wants
any ideas what else can do to polo
  • Replies 10
  • Views 1.6k
both mk5 polo and mk3 golf seats will fit your polo mate.
aswell as smoothing your boot, the join lines under your rear lights look cool smoothed over,
mk5 polo rear lights can also be fitted with slight tinkering, theres a fitting guide on here somewhere
To smooth the join lines under the light do you simply just use bodyfiller
thanks for reply what year does the the mk5 polo go up to will add smoothing that bit to the list
anybody else
The mk5 or 6n2 polo is from 2000-2002.Also you could add a stubby aerial from an s2000 and a debadged grill to tidy it up a bit,yeah but smooth bumpers, deleted rub strips and dropped on coilies should have her lookin well. :-)
Edited by PDUDZ
i think some just simply smooth over with body filler, it may be a good idea to weld the joins to stop movement which could crack the filler, not too sure tho :oops:
Anybody sure on this?
i think seam welds would be better then ground down and abit of bog for the side strips i am going to remove them take the black glue strips off weld the holes grind them back down and alittle bit of bog . welding the holes stops water get in the bog from the back which will make it crack plus welding any holes stop bog dropping . its the bumpers i am not sure of any one got apic of a smoothed bumpers just want to get aidea of what people do to them
So if i just used body filler over them it would end up cracking, is this the same for body filler used in oher places on the car (was thinking of smoothing the side skirts n rear badge)
if theres no holes then should be fine trouble is bog can be fine for years then just suddenly just crack like on the boot keep slaming shut would not really do it any good .you might find the whole lot falls off one day when you have just closed the boot same with the side skirts, with the doors it might turn out fine though if the bog was mixed right :-o
