rocker cover on 6n 16v
wanting to clean up the engine tmoz and eventually getting it polished... basically where do i start the cleaning process whats best thing to do ... if anyone can tell me the process of getting it cleaned and polished i will b greatful...
erm, as you said, clean and then polish?
taking it off might be a good option.
I started to clean up the rocker cover on the missus mk4 using a scouring pad and soapy water. The lil bit i did come up good.
I bought various grades of sand paper,a flapper wheel,a polishing mop and wire wool..I started with the mega abrasive wheel which took all the ptting out but really took the metal back,,then used various sand papaers and wire wool to bring it back as much as i could..Once i did as much as i could then i started with the wet and dry over and over and over finishing with the polishing mop and plenty of metal polish,,I've only done half but its really come up nice.
