Polo side strips
Are they easy to come off? I don't want to take mine off just incase it takes of paint?
  • Views 907
depends!!! what car you got??
i did my 6N using a heat gun, heated up the strip constantly and then prized the strip away.. then with the left over gluey stuff, i used the heat gun again and just rub at them.
you just gotta take it steady...worse comes to worse, stick them back on
good luck
sean
I took mine off 2 months ago, took a few hours with no problem, bought a door of a scrapper 2 weeks ago and with no heat just slipped a credit card underneath an ripped it off not caring (due to a respray a few days later) a 90% of the glue come of straight away with the door in perfect nick. So somethings gone pretty if paints coming off mate. A dab of petrol helps it too!!
i just ripped the old ones off my mk3 and then used a mixture of gentle heat and sticky stuff remover to get rid of the black sticky tape stuff.
Once removed, T-cut the area where the strips were to make them blend in again.
