Polo 6N side repeater fitting
I got smoked side repeaters from Ebay. They were advertised as fitting the MK5 Polo and possibly the MK4.
Well, it didn't fit my MK4.
Is there any way around this?
I was thinking of changing the actual part that holds the bulb to the MK5 one but I'm not sure if this works?
Does anybody have any knowledge on this before I try send it back?
Thanks,
Jay
  • Replies 9
  • Views 1.6k
likely the mk4 golf ones they sent you and they have different bulb holders, unless you get mk4 golf connectors and chop them into the wiring i dont think they are gonna be much use buddy!
send them back i reckon and get them to send the correct ones
This is it:
I don't know if that's much help to you
that should fit buddy, push the old ones eother forwards or back then pull them out of the wing, twist the buld holder off and then tesit the bulb holder into the new unit then refit into the wing :)
wha bam
I took the side repeater out and twisted off the old one but when I tried to fit this one on, it wouldn't fit.
That kinda long round part is too narrow to slot into the connector.
i had the same problem. the thin tube that sticks out from your new lights, i cut off with a junior hacksaw and then drilled the hole big enough to accept the original bulb holder. it is cheaper than posting them back.
DIY job it is!
I'm so bad at these things though.
Ha
  • 5 weeks later...
It's been a long time(because I'm lazy) and I followed your steps.
I chopped the thin pipe with a junior hacksaw, drilled a big hole and then sanded down 1 and a half (of the 3) of the pieces jutting out of the connector that holds the repeater case tightly in place. The repeaters fitted fine into the connectors and they're secure too.
Happy days!!
Could you put a picture up mate?? I've got the same problem as you but if yours worked then ill attempt it myself...
not easier to just flog them and buy the right ones?
