vw polo 1990 mk2 1043 number plate question
the nuts which hold my number plate on the rear have rusted and snapped in place, so i have gond in from behind the panel and removed the plastic captive holder which the screws screw into,
where can i buy the plastic captive holder that the screws go into? they sit in the bodywork and you screw the number plate into these. white long/square shaped.
Edited by GARETHWATFORD
  • Views 1.3k
VW?
or just stick the number plate on using those thin stick pads you can get in motorfactors/halfords
yeah tape over the holes and used double sided to stick it on
or put a nut inside the tailgate wheile the trim is off...car shops sell plastic nuts n bolts for numberplates
If you want to use screws again, I'd get a bag of speed fastners (springy clip jobbies, like you get in the box when you buy speakers) from a hardware shop and run a sel-tapper into them.
Personally though, I'd tidy the holes clean of any rust, blank them with a bit of tape and use double-sided tape to stick the plate on, it'll look far better.
