The polo g40!
I've been looking at a few recently, and am seriously considering buying one!
What sort of things should i be looking at apart from the norms, alot of them have high milage how much of a problem is that? could it be a matter of new rings, shells and valves? i need a project in my garage so i wouldnt mind to much!
thanks in advance!
  • Replies 32
  • Views 3.4k
with high milers, i'd check when the charger was last rebuilt... if ever. may be worth your while getting it rebuilt anyways to give you better performance.
yea i thought about this to! how much would a service kit set me back you reckon?
you can get charger service kits from http://www.g-laderseite.de but it's easy to damage the charfer if you don't know what you're doing. A rebuild from somewhere like G-Werks or Jabbasport will be about £350. Or could also get it ported out for about another £100 or so at the same time. Other than that there's not much to look out for other than the usual mk3 polo things. Although be extra careful to check the condition of the gearbox and the track control arms, all g40 specific and considerably more expensive to replace than standard polos.
after the fun i've had with mine, i'd want to hear it fire up from cold and idle till the chokes off to see what it idles like.
how bigs you wallet
and do you have brakedown cover :lol:
breakdown covers essential !!!!! Not had to use mine yet though ( touch wood!)
x1000000
I've owned g40s for 7 years and cover approx 10-12k a year. I've had 2 breakdowns. 1 was a coil failure and the other was an ecu relay which was dodgy.
How's them apples?
i hate this inexperienced opinion of g40 unreliability! bull shit! I've done almost 45k in mine since a rebuild (currently on almost 145k) and its broken down onece from a tired coil! which could happen to any motor.... compared to some of the shit i hear on here from newer 6n > 9n2's that is damn good going.. an original G which has had money spent to keep it upto scratch afterall they are 15/16 years old will be absolutly fine..i seem to notice the most unreliable g40's are the really high powered ones or the badly done conversions.
g40 boxes are strong the chargers are good for more than 100k mine did that before a rebuild and was fine! the engines ar solid upto around 170+ brake talking to the lads with high powered g40's. mine was fine and had a slight bottom end rumble after a sump leak was not repaired by the previous ower...new shells soon sorted that!
G40's are good reliable cars people who say they are not are 'generally' the ones who dont own them! obviously some will break down as with any car! i know of lads with lupos/9n's etc who have had more problems than my g40.
shell wise check it all over like you would any other car. charger history is nice to know and if it doesnt get a rebuild for peace of mind. again...check www.polog40.co.uk for loads of info and talk to people who own them!!
X2
How's them apples?
the reliability of used old cars is all down to luck about how the previous owners have looked after and serviced them
I have had 2 G40s over 4 years and only had 2 break downs. Both due to clutch cable failure.
I've owned my g40 for 5 years and have never had to call out a recovery company. They are only unreliable if not looked after but you could say the same about any car. Plus people seem to forget that most are knocking on for 18 years old.
only to a certain extent. None of my g's had ever been enthusiast owned or had anything other than servicing done to them - which i'd hope every second had car i'd buy would have.
you admit its down to luck? but say their unreliable - make your mind up!!!
see people who own them know the score not the people who read rubbish on the forums....experience is what counts i drive my car every single day and its been great...if it breaks down i will fix it simple.
its a bit like going to a bad restaurant - you tell everyone, a good one you barely mention it. Therefore people with problems ask here, people without just get on with it!
I've had my G40 for 4 years and in that time it has never broken down on me yet.
Sure i've had the clutch done and a new fuel tank fitted aswell as brake pipes,hoses
ball joints etc but these were all done well before they gave up completly.A G40 is no
different to any other motor on the road imo.....
wow you people are really helpfull! as for the charger rebuilt, i reckon i could give that ago I'm quite mechanicly minded, no1's ever workd on any of my cars but myself so far, not to fussed about breakdowns either i use to have a 1993 mini, so it will seem reliable lol,
just wanted to know if there were any issues they all suffer from but if its just the norm thats great! if i get one with high milage ill just do a lil rebuilt and it shall live again! better to do it before it starts knocking right?
thanks for your help tho! when (not if) i get one i shall post some pics up
thanks
I never seem to fail on using all 6 of my AA callouts each year :lol: Not just the polos though to be fair, the mercs claimed a good few.
Managed to snap yet another driveshaft yesterday. Must of had about 5 or 6 sets of oil seals go in the last few years, and a couple of center bearings (thanks pitstop) Good few gearboxes, melted a piston, few headgaskets. All part of the fun.
The standard one I had never broke down even once...
Iv broken down 3 times in my g40 in three years, number 1 was a melted piston (mileage was 181,000 miles!), 2nd was the diff failing and 3rd was the clutch cable.
I have done 74,000 miles in the 3 years iv owned her, current mileage is at 245,000. So i can say they are pretty reliable if they are looked after. Iv decided to re-shell it now though as it is very, very tired as you would expect! :lol:
Have to put up with the slowness of of my daily 1.4 6n for a year now! :crybaby:
so correct me if I'm wrong, alot of the standerd g40s, are pretty much troublesome as a normal daily. and modded one proves more headache?
just out of intrest, whats the most bhp someones got out of 1??
most of the bad things you here about unreliable g40s are down to neglect as previously stated but also tuned ones with incorrect maps which leads to piston meltage.I personally have had 4 g40s on the road over 7 years (3 at once its a desease) and only ever had 1 problem that meant i had to get towed home which was caused by a blocked crankcase breather and oil pumping out of the dipstick and got on the exhaust manifold and caught fire.luckily i had a fire extingusher but new breather and all was sweet.I've had things like coils,dizzys ect but all cars are like that and my 6n is more reliable with a g40 in than it was before with the 1.6
luke
georgios is running roughly 200bhp (when its running!) but i'm sure he'll put give you the correct figure. I'm looking to get somewhere near this figure without compromising reliability so everything that can be changed will be.
Most bhp for a 1.3 8v derived G40 block is in excess of 230bhp- with 180lbft of torque, have the dyno printout at home somewhere (was my old engine pre turbo) Although turbo gives 195bhp and 185lbft- so is quicker generally.
With gas I've hit 214bhp and 208lbft, although hopefully should have some better figures this Saturday at the Club G40 rolling road day :-)
With regards to buying a G40 I'd reccomend you budget a minimum of £750 for necessary service parts, the cars themselves aren't unreliable (far from it) but as with any performance shopping trolley to require attention to keep them in good working order. As good practice I'd say the following:
Oil & Filter Change
Air Filter (OEM one or K&N Panel- Not Foam)
Waterpump & Cambelt (Cost you peanuts, a little fiddly)
Charger Service (G-Werks for this)
New Plugs- Bosch W5DPO
New Rotor Arm, Dizzy Cap & Leads, new coil if you can afford it
New V-Belts & Belt Dressing
Then a check of the key electrical components (CO Pot, Throttle Switches, Map Sensor, Blue Temp Sensor) And replace as/where necessary.
The above is well under £750 worth (only the charger is G40 specific) so all in all not a huge deal more expensive to maintain than any other Mk3 Polo
Pete
