G40 1341cc engine
G40 1341cc Engine
The engine is from a J registration G40 and has done about 160,000 miles in total. It was rebuilt at about 145,000 miles using PSD accralite 77mm pistons making it 1341cc.The main and big end bearings were replaced along with all the bearing cap bolts, head bolts, oil pump the oil pump drive chain. All gaskets and oil seals were replaced and the rods were also balanced. The head is a big valve(1mm larger exhaust) ported head which was done by PSD using new exhaust valves, valve stem oil seals and hydraulic lifters. It is fitted with a standard cam at the moment but I will include a PSD Newman cam which I purchased but never fitted, it also has a GT inlet manifold ported to match the head and PSD 51mm ported and de wedged throttle body. There is a custom made alloy radiator and intercooler with the engine as well. I will also include the alternator, starter, boost pipes and wiring loom. I will split if there is enough interest.
OFFERS AROUND £1100
All items are for collection only and are located in Burntwood near Birmingham
Email or phone Andy on 07879686104
Edited by Andy78
  • Views 440
is this for the engine to take away or to trade with a standard engine pm me the best price u will take I'm very interested
Edited by ian_g40
