refitting quarterlight glass on mk2
my mk2 coupe has for some reason had one of the front quarterlight windows removed. i have the glass and the seal but i just wondered what the easyest way of gettin it back in would be ?
  • Views 880
Wind the window right down, remove the two rubber seals/guides the the window slides up against, remove the door card(four screws/pops off) and then undo the B-pillar: one screw on top of door then the other is more like a bolt at the base which you will see when the card is off.
The pillar is a bit of a fiddle to remove just find the right angle and remove it carefully. Then you can fit the glass and seal all as one unit. Tip use a bit of grease/soap to slide it right into it's corner.
Good luck, I apologize if I've miss interpreted your question.
Edited by MacColl
ahhh, didnt realise that pillar came out cheers buddy
