Poorly polo :-(
Just wanted to share with everybody how knackered my polo was yesterday when i (slowly) went through a HUGE puddle of water...
...i got about a quarter of a mile further up the road and stopped at the traffic lights. As i went to pull off, it felt like the car was pulling off in 3rd gear so i made sure it was in 1st and when i tried to pull off the power was really low and it was juddering on idle when i pulled to the side of the road.
My mate told me that it was probably water in the induction so i revved the engine hard and eventually the white smoke stopped pouring out the exhaust and it began to idle properly.
Just wondering if anyone else experienced huge downpoors yesterday? I am in the Walsall area of the West Midlands but i drove down to Kidderminster and it was really bad there too. Lots of roads were flooded everywhere!
Is there anything i should or shouldn't do with my polo since this happened? It seems to drive ok with no problems but is it worth changing the oil or anything like that?
Cheeeerrrss :):):)
  • Replies 28
  • Views 2.4k
hmmm white smoke could be burning oil.... which could mean your headgaskets going or you are piston rings
Edited by xcore
if you had taken water in it would have hydrolocked, prob just a drop or two on an ignition component
If you had moisture on any ignition parts.. You arent going anywhere!
I would have said water had got into the bell housing.. making the clutch slip slightly.. had it before on a mk4!
Probably just got water in the dizzy cap/ ht leads, a quick squirt with some wd40 will sort it out. White smoke is burning water though, oil smoke is blue. Abit of water may have got in the induction, but not much because it still runs. Lots of water in the induction basicly destroys the engine rather quickly
My golf died saturday night for 40mins when i went through a huge puddle, just left it to dry for a while and off i went, did the same thing as your car.
Can't have been knackered gasket or rings cuz it was too coincidental with driving through a huge deep flood lol and also it drives fine now with no smoke at all (shot rings or gasket wouldn't have corrected themselves like that).
As for hydro-lock, well, i would've thought it would've killed the engine too, but water on an ignition component wouldn't have caused smoke to come out the exhaust, just lumpy running... unless water went up the exhaust and as far as the engine because my cars low enough to submerge the exhaust but it shouldn't go up the exhaust due to strong back pressure etc???
Any need for oil change or anything lads?
my mate overfilled his astra with oil(nob) and white smoke was pumping out of it
yep carn't compress water.
Should be okay.
No, turbodaily is right.
Oil smoke is blue, white smoke is water/condensation. Like he said, a bit of water probably got in the induction system and on the ignition components.
Nothing to worry about mate. 8-)
i went through a very deep puddle on the way to work today was all fun untill it went over my door seals :(
This used to happen to me alll the time on my golf!!
Went through one once and then got pulled!! Lol I think volkswagens just generally dont like bad weather! Lol
Lol to clear it up, i think both types of smoke are similar but the water is white (like steam) and oil is obviously slightly blue tinted smoke.
I'm sure it was just a bit of water in the induction but i think i'll change the oil anyway because i don't like the thought of my sump being 3-4 inches deep in water even if it is meant to be sealed! May run a bit of injector cleaner through it too.
Ed :)
Was bad mate, you know barrons court in walsall wood? I had to turn around because i didnt wanna risk being floated away!
Was bad the other route i took too, but not AS bad.
Bloody weather ehh?
my polo done the same started it up after a lot of rain it went up halfords it stated splutering a bit i came out and it wouldent start lol so got a lift home with a mate a left it there walked mk up halfords 3days latter when the sun was shineing started fiirst time dorve all way home no problems still does it now a litle when its damp tho its water getting in it somewere lol
mines also done this sounded like a subaru hahaha shame it didnt go like one tho :( it shortyl sorted itself out after keepin my foot to the floor and revs high lol
Lol funny you should mention that because sunday night i also tried going down past barrons court and ended up turning round and throwing a right turn into brickyard and back to walsall that way instead :(
Yeh, my car was chuggin like a subaru but it was going like i had put full fat milk in instead of unleaded.
what turbodaily says, happened to me donkeys ago in mk2 camper - thought me engine was buggered, waved aa man, rattled shinies and he laughed , cleaned out the rotors and squirted wd, no probs.....
happened last week in polo, just let it sit for in idle for a couple of minutes...
So thorough cleaning of the dizzy and HT leads is in order?
Thats what i said! :roll:
yeah theres 8ft of water covering the main road about 50yards down the hill from my house!
Myself and Toby had a little incident like this at the Polo Show this year, went through a puddle so deep a Range Rover struggled,
spent 15minutes at the side of the road revving all the water out my car...good laugh though :lol:
I've come to the conclusion that was actually a river and your satnav is gay.
The Bentley side of Junction 10 is always flooded, hard to turn round too!
I've been splashing through the puddles on purpose.
Didn't do a thing to the car lol. only thing was the water slowing it down and steam afterwards.
Been a fun weekend with all the rain, the polo can do more than some of these wannabe 4x4's.
