'Damp' Interior 6N
Recently I've been getting condensation on the inside of my windows in the morning. It goes when the car is warm. I got something out of my boot the other day and noticed there was condensation on the boot floor, under the boot carpet. Anyone experienced this or know what the cause may be?
  • Replies 8
  • Views 1.9k
probably just your door seals starting to perish.
in your boot, have you changed your rear lights or removed and refit at some point?
check they are nipped up and the seal is seated better, likely its coming in from the back end
I've been gettin that all inside the windows its so annoyin, i drive the car leave it with no condensation on the windows and then when i get back to my car its all fogged up and the condensation is on every blody window lol.
i saw your car for the first time at norice yday!! luks like a beast! nehu check around the pollen filter housing and make sure your plenumb chamber isnt blockd! (the area around the pollen filter housing which is usauly blocked with leaves)!
I have changed my rear lights. Will check that. Also I get it on my windscreen but seems to just on drivers side.
check ure pollen filter that wont help either
likely the rear lights, changed mine and they leaked like mad. Also, make sure your central locking pump is dry (in the first aid compartment in the boot) and maybe wrap a plastic bag around it- cos a bit of moisture will knack it....
Leave your door open for a minute when you park up to allow the cold back into your car :-D
