MK3 door hinge pin repair?
...has anyone done it? Are new pins available?
My drivers door has 'dropped' consdierably
Any help would be great!
  • Views 5.2k
you can buy new pins for sure, no idea how easy they are to fit, as I've never tried
I did mine not too long ago mate...not too hard to do but you will need a
bit of help getting the door in place.You'll need these parts....
Hinges....VW Part No 321831403 £8.92+VAT each.
Hinge pins....VW Part No 321831421 £3.62+VAT each.
Hope thats of some help....
i done my my mk2 , used the hinge half and a new pin
its pretty hard work to bash the pins out , you need to support the door on a trolly jack and punch em out with a quality punch/drift and a large hammer, take care to noticed one end is slightly pointed compared to the other , bash it so that you hit the pointed end
if you have access to a scrap yard mk2 golf rear doors should yelid the parts for this
I used a passenger door pin from a breakers (free - after offering) with some copper grease.
But even with the latch-pin adjusted and the door operating clinically,it was still a fraction low - so i got on my knees,cupped my hands under the acutely ajar door,and lifted the side of the car a few inches,until i had approx 60-80kgs of weight in my hands.
This was more than enough to stretch the hinges to the required position.
