MK3 Wing mirrors - repair or replace?
The mirrors on my MK3 Genesis have give up!
The spring washerthat holds the mirror in a fixed location seems to have corroded and I now have droopy mirror syndrome!
Any ideas on replacement or repair?
Incidently mine are the cable operated type
  • Views 1.5k
No disrespect intended,but sometimes i see a question and i just think.. 'well,duh,how about a little inventive thinking here?'
But i appreciate it takes some time to develop a pikey-tech attitude to life,and i once asked a mechanic collegue (he did the technical,i was a coachbuilder and did the bodywork) why my wheel sounded like it was falling off. Guess what..?
Anyway,here's some inspiration for you - if somethings loose,tighten it. If its worn,find something that resembles the part when it wasnt worn.
Hey,how about removing the 90s televisions from the mounts,and bolting some matt black Tornado/Bullet mirrors to the standard mounts? See? Easy.. They wont still be remote control of course,but how often do you adjust them?
If you like the telly's,take them apart,clean them up,replace anything worn or modify accordingly,and refit.
Any ideas where to get cheapo bullet/tornado mirrors - the polo is my budget winter ride!
They're popular on old minis,so must be advertised in mini magazines. Try mini sport,huddersfield spares or the biggest one - mini spares centre (i dont know exact addy's).
cheap budget repair is any mk3 you will find in a scrappy, a phillips screw driver, and about £3.
They're a bugger to take apart and get back together. I'd replace the whole mirror assembly with one from a scrap car.
Basically, you need to take your door card out and the peice of trim at the front of the quarterlight and all will be resonably obvious.
Quick tip. Tie a peice of string to the adjuster lever on the old one before you pull it out. That way you can just pull the cable on the new one back through, which will save a lot of swearing.
