Polo GTI mileage questions????`
Hi guys i am looking for a polo GTI and have found one with 119k on the clock,
it seems to be in good condition and has had new clutch along with regular servicing etc etc
my question is is this rather high miles how long has the engine got left in it? and how long do they usually last for
also are there any comon problems i should be looking out for when viewing one??
cheers for your help in advance guys
chris
  • Views 898
hey that engine should last for at least double that milage the only thin gyou need to look out for is the gear box as these are a common fault on these aslo check when the cambelt was last done but at the end of the day these are both replaceable it depnds on how much you pay for it as with that sort of milage i wouldnt pay no more than 3.5k in mint condition for it with all these faults changed
Thanks mate
I will check the cambelt but i would be changing all the belts filters etc etc just give it a huge service making sure everything is in perfect order.
Gearbox may be an issue on this car then? how much does it cost for a new gearbox? i can fit myself, what is it that go's on them specifically? the synchros?
yep, the cambelts have to be done pretty often on those (think its every 40,000?) and those gearboxs are cack if it hasnt had one expect it to need one!
well i done mine my self and the box cost me about 450 its a easy job to do and will only take about 3 hours if you gto the new 1 sittin ready to go in
Thats not to bad then.
cheers for the advice, hopefully getting it tomorrow so i will get some pics up or something
thats ok mate yer get the pics up when you get it
