Window Tints
Iv just heard from a mate, who told me that the cops also make you take your tints off even if your car comes standard with tints on. Surely if your car has factory fitted tints its legal? or not?
  • Views 1.7k
they cant make you remove factory tint off, the are legal as they let enough light through.
The police have a device called a tintman which is a light and a meter. The meter is put inside the car then a beam of light is shone at it, tints must let 85% of light through unless it was registered before 1985 then it's 75% IIRC. I was also told by a the police that even some clear security film can make a car fail a test.????
Front windows have to let in 75% light through. If they are too dark you get £30 fine and can be points depending on how dark they are.
my mate had too take his off there and then at the road side and had the lightest tint you can get
my mate who owned the car before me was made to peel the front ones off there and then but never said anything about the rears which are limo.
do you think ill get told to peel the rears off if i get pulled?????????
Rears you can have as dark as you like, from what I've been told.
Edited by VeeDub9n
yer rears can be as dark as you like
