9N3 Wing Mirrors.
Can anyone tell me how they come apart?
I want to know as I'm thinking of spraying them, but only really if the plate comes off leaving the indicator and everything as it is. I will be buying new bits to spray in order to keep the original ones.
I want to spray the bit highlighted red in the photo.
Also, how do I get it apart? My Haynes manual can't help as it's for the Mk6 only which didn't have this style of mirror.
I imagine I'll be able to get them direct from Volkswagen?
  • Views 2k
I've not taken apart the ones with indicators, but if your buying new parts to paint you'll be able to see how/ where the fixings are on the new part. The ones for colour coding will come ready primed needing only a light keying up with a grey scotchbrite or abralon before painting.
Thanks for the information.
Anybody else able to shed some light on this?
So, going to get some of these ordered tomorrow, they won't be ready primed though.
Can anyone tell me the best paint to use? I guess I will need to primer and then paint them.
They are just plastic, but I'm not sure which paint will be best for this.
Just a thought, if you've ordered new mirror covers on your chassis number and your car has the black textured covers as standard, then this is what they will be supplying you again. Different spec'd polo's that have colour coded mirrors as standard would be supplied with new covers in a light grey primer, ready to be painted. ( they are also smooth with no texture.) You can paint textured plastic, but it has to be rubbed down, a plastic primer applied, then high build primer, rub this smooth and then topcoat with colour and clearcoat. ( a lot less hassle getting the factory primed items :-) )
Oh well, you live and learn.
I take it factory primed items wouldn't be much more expensive either?
These ones were only about £8 each.
Thanks for the tips, at least I know what I have to do.
If you explain what your doing to the vw parts guy, and he's in a good mood, he may let you swap them for the primed items with you paying any difference in price. We paint a lot of them at work due to them being easily damaged and so he's more likely to take them back than if they were a specially ordered obscure part. Worth a go anyway.
