Wet passaanger floor??
hey guys.
got in the car this morning and it stank of stagnant water etc.
had a look in passenger floor and its soaked with water?
pulled the carpet back where the trim by the door meets the trim along the underside of the dash and theres a few wires with foam around them and around that there are a fair few drips. just wondering if its likley that theres a hole in my scuttle tray or is it something more simple?
any help would be muchos appreciated fellow poloers!
they often leak behind the door cars...whip the card off and make sure its all sealed under there
Had a similar problem with my mk3 polo just recently.
The carpet in the passenger footwell is wet and its wet right under the seat into the rear footwell. I pulled the carpet back a bit and it looks like it's coming from some just infront of the door. Any common faults??
Not stealing your thread jay just similar subject!
yep, mines jsut like your oli. pulled the carpet back under the adash board and can see a few drips around where my cables come in the car and along the passanger side of the door to hte boot. I'm going to start with scuttle tray and see if thats the problem.
i had quite a similar problem with my lupo.most of the time it drips into the car by using some holes witch aren´t cloesd properly by a rubber stopper or the ventilation system.
the other possibility (as oli already told) :the clingwrap between door panel and the door itself could have several holes or clefts.these clingwraps aren´t availible anymore (as far as i know).but u can also use some other tough clingwraps.
best thing would be to remove the seats,the carpet and the thick mats below the carpet so that you are car can dry and you see more...
wet cars are dumb....good luck :)
welcome to my woes!
i had a few replies in my thread about this
clicky
i think some of the responses in their will help you both!
