serious condensation problem
got a really bad condensation problem with my mk3 polo coupe. if its in direct sun it becomes so badly condensated the windows look frosted and really humid and stuffy inside. until a month ago it had sat still for 8 months as work was done on it and i'm assuming this didn't help.
i've just got some condensation crystals to take the moisture out of the air and dry help dry things out. gonna get it professionally cleaned as well. saw on a different post that door seals might be an issue
any other ideas on solving it? i know old cars will suffer condensation but this is extreme
  • Views 1.4k
could be the door seals. Is there any are in the car where its worse than the rest? Some leak though the light cluster holes. Mines a sod on a cold morning but i think it ssomething to do with where the power cable for the amp is routed.
sounds like it might have a leak ? be worth having a poke under the carpets to make sure its dry , especialy under the batt tray etc
will do, guess this adds 'character' to the car
thanks
thanks
id say more like causes the floors to rot out tbh
