polo mk3
aight I'm new to this forum but loving it already, I've found meself a mk3 polo genesis on a k reg, went to view it today
basically founda few faults with it, it keeps making a beeping noise every now and again whilst driving, its a continuos beeping,when it happens
if u kill the engine and start her back up shes orite for a bit then again.. any ideas ?
also i noticed it looked like there was oil weeping from about the head gasket area(left hand side), the guy tried saying to me that its
a common fault on the 1.3's any ideas people?
any replys would be great as i really wanna get meself a polo,
cheers tj
Edited by toca
  • Views 889
the beeping noise, is it a buzzer going off? If so, thats oil warning buzzer meaning the oil level is low. Check the oil level to see if it is. If it isn't, there maybe a wire off on the back of the head but by the sounds of the oil leak you mentioned, the car needs a new head gasket so will be losing oil.
hth.
Jon.
I'm sure you could say an oil leak is common with any old engine :lol:
If you can do a headgasket yourself that would be a good thing to do if their isnt much history.
aye its annoying as its a repettitive beeping i must say it did only happen when it was warm like,
head gasket should be just a saturday morning at work, got accesibility to workshop ramps,
