mk3 polo 1.8 16v project help
hey guys i aint been on for a while due to me not owning a polo no more but i been thinking i want another mk3 polo and i fancy putting a corrado 1.8 16v engine in one and was wondering peoples oppinions and if you think it would fit in a mk3 and if it would take much work, i could reli do with the help on what breaks would fit and would be best for this ect and suspension i would need i would most likley go for coilies but I'm unsure on a few things as this will be my first project any ideas or if you know if its been done before would be a great help guys, thanx
Martin
  • Replies 10
  • Views 1.4k
Tall block engine? No chance i'd have thought..
I wouldn't bother, sump on the floor and rocker cover on the bonnet lol You will need to make a subframe as well, i have seen it done but not well.
Plus the weight up front will be killer, go for a g40, 1.4 16v or a 1.6 AEE on bike carbs or GT injection.
seen a 1.8 8v mk 3 polo in essen a few years back looked the bollocks -he had made a subframe for it to sit on .
The subframes cost 1500 euros on their own!
if you have the money and the balls - it can be done
if you doing it for a laff - dont bother it takes sooo much time and so many custom bits. your wallet will hurt aswell as you need a proper pedal box etc etc.
+ add the fact you would have a heavily weighted front end on a chassis that cant handle a G40 motor without it snapping
I looked into this recently,and it'd be far easier than everyone claims. You dont need a subframe,can use standard Polo setup,the engine in question doesnt have too much torque for it,and there's a small gearbox you can use (085 - 6n 1.9 diesel) with Polo clutch and front-mounted starter. But its cable-shift.
However,i still aborted the idea because it'd just be such a pain compared to other options - the engine wont physically fit unless you move the box a good 1.5 inches further nearside,and that's some serious camber on the front nearside wheel because you're not getting a driveshaft 1.5 inches shorter. The anti roll bar wouldnt reach,either. And the offside anti-roll bar mount would foul the water pump in any case.
However. If you can fit a remote water pump (remote electric water pumps are available),and mount a drive for the alternator higher up (above the chassis leg),then the gearbox only needs to be shifted half an inch across from its original position - allowing you to use standard suspension and drive shafts with camber tca arms available (the offside drive flange already has the spacer you need - its longer on the 6n diesel box).
Then you just need to fabricate an engine mount arm (this would be good for the alternator drive,though you'd need a longer cambelt) to bolt to the engine somewhere - there are a few threads on the block,its do-able.
I'm pretty accurate - as i say,I've looked into it in depth. But please do bear in mind that I've not actually done it..
A 6n2 Polo 1.6 16v GTi engine would be far easier,almost straight swap,and gives almost the same power - and is notably lighter. And probably cheaper,all in all.
You may not need a subframe,but it'd still be a serious pain in the arse for little gain.
You may not need a subframe, but it'd still be a serious pain in the arse for little gain.
The last line in your reply says it all Mikey.
The pros are far outweighed by the cons with this conversion.
I can't believe how many times this question comes up. Why is it that people think it may be a good idea to use the 1.8 16V engine anyway? It's not like they are very powerful, they're heavy and as much as anything bulky too. Why anyone would want to fit one of these engines into anything is beyond me when there are far better options available. Much the same can be said with VR6 engines, heavy, thirsty and with poor specific power.
It may be cheap to buy a 1.8 16v engine from a scrap Golf, but most have massive mileage and the by the time you've squeezed one into a Polo (and ruined the handling and balance) it will have cost you a lot of time and money.
And for what good reason?
They're really not much bigger,and it'd tilt forward in the polo with that gearbox,just as the diesel version tilts forward in the 6n. I doubt it'd even be that much heavier,but for the redundant casting at the front for the dizzy drive adding a door-stop worth.
What makes them such a pain is that they share nothing more than the oil cap with the other engine - the inlet/exhaust manifolds are reversed,external water pump,front mounted starter,said redundant in-block vertical dizzy,the two engines couldnt be more different if they were designed by another species.
you need to chop the chassis legs both sides, and the subframe is for the front engine mount and stiffening the now weaker chassis - not for the sake of it.
i have a guide from which i will post pictures later on and kill this thread off - and all the other which spin from it. - in fact sod it! il put a guide and pin it
You dont need the central front engine mound with the small gearbox,as it has two mounts - so no subframe.
The engine just offer a mount to the chassis leg the same as the small block. And no cutting of the shell is required at all,it fits between the legs - but only without the aux drive.
