Just Joined - Looking For Advice
Hiya
Just joined up as i am looking for a Polo GTI the 2001 shape not sure what its called technically :? sorry !
Had a quick browse of the classifieds, but is there anything in particular i should be looking out for on these ??
Most seem to have quite high mileage, I am looking at it for a second car and assumed most would bo of this nature.
Thanks for any info :)
  • Views 991
The Mk5 Polo GTI (or Mk3f to VW but i wont confuse you with that now) is one of those cars where the high milage ones are the ones to go for in my opinion. They have an infamous gearbox problem (they keep shitting themselves) which on a high milage example is more than likely to be sorted or have a nice new box on it.
Thats the only problem I know of on them, so other than that just the general checks you would carry out when looking to buy any car.
Thanks for the info. Have seen a couple with gearbox repairs or changes which i was alittle worried about, wasn't aware of them being fragile so to speak.
If they do go pop is it possible to uprate or replace with a different box ?? Maybe 6 speed one out of the lupo's ??
I dont think the lupo box is as straight as a conversion as it seems, but I'm sure someone else will tell you for definate.
Welcome to the club :)
the only replacement boxes that will fit are gti or 16valve ones as they are not rod type.
the lupo 6speed box wont fit as the casings are completely different (unless you fancy some hardcore fabrication)......
these boxes are literally made of chocolate trust me, so when test driving make sure you listen out for any whines etc.
There we go i didnt think it could be done easy, good luck with finding a good un anyway :)
Cheers once again for the info. Shame about the boxes being pooey :( Might be a non-starter as we want it as a second car which the missus will use with little one in it. Dont want the hassle of any problems if it can be avoided.
Will continue my hunt, if i can get one at a decent price then i could just fork out for a rebuild or whatever is needed just for peace of mind. Assuming everything else is fairly reliable on them though
