Changing A Rear Window In A Gt
Hi can anyone help, some MF smashed the rear drivers side window of my 93 GT. I have managed to get a replacement from theee bay, but wondered how easy it was to replace myself. I have taken all the glass out of the seal and its in good nick. Are there any little tricks to putting the new one in, like soap and string and anyone tell me what to be careful of. Many thanks.
dont use your hands to push it to hard (wrists + glass = :( )
take the rubber out of the car and fir it onto the glass with a little bit of fairy liguid between the 2 then cover the seal between bodywork and rubber with fairy liquid and feed a bead of string around the rubber channel
take the rubber to the window and begin to fit the rubber, use of screwdrivers and flat ended items are good here, take the string into the inside of the car and once you have the rubber nearly there slowly pull the string inwards and this will pull the lip over the lip on the bodywork
^^^^^^^^^ as the man says but use anything slippery but not detergent as it loves to EAT metal big time. :shock: my mum used to wash her BMW with "fairy" then one day like magic rust rashes appeared everywhere and it was terminal and it was a N plate!! So anything that doesnt make u look gay when u buy it in the shop but is slidy lol go for it as if you pick the right stuff it might act as a protective layer over the metal too :thumbsup:
Cooking oil would do, no?
silicone spray :)
Bit late here,but when i re-fitted my rear windows i didnt use glass,i used polycarbonate.
Eighty times stronger than glass,cheaper,lighter,very easy to kick out from the inside yet laughs off flying kicks/bricks/hammers etc from the outside,and easy to fit as its flexible.
