6n2 Seats?!
Hi, I want to change the drivers seat in my 6n2 for a height adjustable version (bang my head on the sunroof surround at the mo :? )
Can anyone tell me if the 6n ones will be the same or do I need to get specifically a 6n2 one?
Also assuming that I can take the cover off and put my existing one on, has anyone done this and is it doable?
Thanks,
vern
  • Views 1.5k
you could fit the gti seats they have an adjuster on them but dont know how easy it would be and if they go lower than standard one's???? hope someone else can add some light on the seat situation for u.
good luck lanky :p
Thanks,
vern
Hi Vern I have got the same problem. I am finding the seats to high on my polo. My car is a saloon so I am not sure if the seats are the same as hatchback cars. Did any one give you info regarding seats?
I think the SE have height adjustable seats. Might one to try that.let me know how you get on.
Regards
Vesh06
Golf mk3 ones fit, the GTI/VR6 ones are height adjustable.
or just get your "gangsta lean" on.
mrk 4 polo 16v seat fit and adjust :)
mk4 CL spec seats will fit too and are height adjustable on both sides. Failing that as mentioned avove mk3 golf seats can be fitted relatively easily.
Just checked back on this, thanks everyone, trying to source adjustable subframe from scrappy at the moment :-D
