Help Fitting New Momo Steering Wheel
Hi all have a new Momo steering wheel to put on my Mk 4 Polo.
I have the Boss kit so all parts i require I've got!!
Any tips on fitting will be greatfull...
I have the standard wheel removed so ready to fit new one,
Matt
Bolt the wheel to the boss with a couple of the screws so you get it all squared up the way you want, you will then need to remove the wheel from the boss with the boss in place to bolt the boss to the column.
make sure the wheels are PERFECTLY streight with the std wheel (i found it best to drive streight for abit so you know they are perfect then stop, take std wheel of and put MOMO one on.
MancMike fitted the boss kit to his car when he owned it so he should be able to help with fitting instructions e.t.c, I've fitted one to a metro (mini basically) but its abit differant and doesent have the horn rings e.t.c.
With the mk4 boss kit there are the horn rings, now these i never knew where they went (didnt see the std setup with not removing the std wheel)
I'm sure if you work out where the horn rings go and the wheels are perfect streight I'm sure it will be a case of just bolting the new boss and wheel on. :thumbsup:
Thanks for the replies guys !!!
I'm still stuck on the horn ring e.t.c not really sure how to fit it ???
Any help will be good
Matt
well the big notch on it i think goes in a notch in the steering colmn to centralise that part then the wire from that goes through a notch in the boss to plug into the horn push button thing
