Fitting Mk5lights Done Something Wrong But What
hi fitted my mk5 lights today done the left one fine all works but fitted the right one and when i put the indicators on the fog light flashes as well i swapped the top 2 wires around (so thick brown is at bottom)is there more to do with the right one because of the fog light :-(
  • Views 1.2k
With the right one your meant to turn the connector around so you put it in upside down thearectically(sp), thing is you can't because the connector has a little clip on the side so you can only put it in one way round. You have to cut the clip off, (use a hacksaw took me two mins) then put the connector back in up side down and it should work that's it. :thumbsup:
you cut off the two rectangle bits so you can put it back in the other way round
here's the thread for you
http://www.tigerstyle.co.uk/poloforum/viewtopic.php?t=9117
Edited by H@wK£R
Mr H@wK£R (damn why cant you have an easy to spell name :lol: ) has it, just turn it upside down
Edited by POLOMON
Haha, i used to be called 'james1989' but i got bored with it :lol: thought i'd try something different, although it's quite annoying when i have to sign in :lol:
Edited by H@wK£R
HAHAHAHA! auto sign in FTW :p
You quoted my incorrectly spelt Mr too :-( BOOOOOO!
I've edited it for you :-D
Edited by H@wK£R
:lol: :lol: Cheers :p
EDIT: sorry about all the spamming hibbs :oops:
Edited by POLOMON
cheers for the reply will do it tomoorrow :-D
