Mk2 Owners ...anyone Change Thier Dash Lighting?
just for something to do I've been thinking about fitting some leds in the mk2 polo dash cluster
was considering blue dials , red digital clock and switches like a mk4 golf?
any thoughts on what might look nice , kinda thinking it might look a bit too chavy on a old car
Edited by steveo3002
  • Replies 10
  • Views 5.3k
i was planning on doing mine all red. be warned though the clocks use different leds/lamps to the ones used in mk3 ones, as i found out when i went to fit the spare red ones i had left over from one of my mk3 projects!
was just gona make normal leds fit into the cluster and wire em up , think its gona take a few extras to make it light evenly
I think your last line sums it up TBH Steve. Personally I'm not really into changing the colour, I don't think old cars like ours look very good with red, blue etc illumination.
However, you could use LED's instead of the normal bulbs as these are prone to blowing.
hmm yeah I'm in two minds
i already fitted green ones in the heater slide..its made a nice improvement as it never lit at all lol
spose i can always change it back if i change my mind
i think a single colour would work fine, i personally hate the green, which is why i wanted to chenge to red. i wil probably change mine by making new colour filters to replace the green ones though rather than use leds, as they don't light very evenly like you've already said
I've never even thought about doing this basically because I've had far bigger terminal issues with my car but yes I think one colour like blue or red would look cool but still subtle oem enough. Think I remember your thread with the lights on the sliders which looked good too.
I'm set on simplifying my dash to the absolute minimum. I recently got another square with a cigarette and stereo blanking plate which I would love to use and just get an amp with an I-pod connection. Also the dash on this car has the most simple speedo I've ever seen with no clock which I like the idea of using but I'll probably never get round to it.
Pics when your done!
The standard green floodlighting is achieved by a green diffuser strip along the top of the instrument binnacle,which has two clear lamps behind it.
Changing that strip for one of a different colour would have the effect,though it'd have to be frosted.
Then there are the lamps behind the clock faces. Coloured bulbs behind there would give you a rear tone (white as standard).
LED's make sense for their longevity,but the directional beam is an issue - even pearl ones are directional,unlike element bulbs,which isnt helpful.
The cigarette lighter is green only,but I'm sure other colours are available,i know orange is.
Personally,id like the whole lot done in orange,with red floodlighting. Still simple,still retro,but easy on the eyes and warming.
I did mine red on my old Mk2.Went along to Halfrauds,bought a
bottle of red bulb paint (yes there is such a thing) and painted
all the bulbs in the dash.There is a downside to using bulb paint
and that is that every so often you have to paint the bulbs as they
gradually loose their colour after a while.
some audis /later vw's audis have red cig lighters , although it wont change when off a superbright led will totaly overpower the green bit anyway , i tried a blue one for a while
seen here...gone back to green for now
heres the slider i did...looks overly bright in the pics but i can dim it down if req
also done light up slider knobs for my golf and the switches
