Another Newbie
Hi Guys, I'vebeen considering making a new dedicated track car for a while now. (Well since the last one died actually.) I was quite keen to use a polo mainly because the weight. I have owned one MK1 and two MK2's before in my younger days but these were kept stock, so fairly new to the polo modding. I have just aquired a MK3 breadvan which I think will make the perfect starting point.
My plan is to try and keep it as a bit of a sleeper. Well as much as you can for a track car. So I would like to keep it steel wheels and keep the bodywork as is except from some drastic weight saving. Any advice, tips or points in the right direction, which parts are best etc would be great.
I also have another dilema. Because I am me and I like to be a little different, my plan is to fit an AAZ 1.9TD engine. I know you are all asking "why?" Because for free you can mod it from 0-60 in 22s to 0-60 in 8.5s, now imagine that in a 700kg car and still getting 60+mpg. It is always good turnng up at a track with a clattering diesel and then giving some surprised people some grief on the track. Has anybody ever done this or considered this? Any thoughts or ideas?
  • Views 925
sounds like a task getting a 1.9 diesel in there lol
good luck
Major hassle - its the big-block engine,which the pre-'94 Polo wasnt designed to take.
And when looking into doing it myself,i wasnt trying to get a turbo in there aswell.
But anything's possible if you're determined..
And I am very stubborn. :D Correct me if I am wrong but isn't the 1.6 engine a tall block too? My thinking was the AAZ will probably have to be mounted to a subframe therefore can be made to sit lower in the engine bay and if necessary shorten/widen the sump.
How far did you look into doing this conversion? Was it just the height issue putting you off? Also as this will be a track car, the bonnet could be raised slightly at the rear on bonnet pins. Coud gain another 1/2 inch.
Theres a couple of sleeper Mk2/3 breadvans on here.
If you're that stubborn, any engine can be made to fit (within reason) but if you want things slightly easier, Buy a PY engine (G40 lump) and replace the G-lader supercharger with a turbo. 200bhp + 700kg = fun!
