Mk2 G40
Found this on fleabay
item number : 200280070223
Do they have different g-laders to the mk3 g40? It says its got an original mk2 charger?
  • Replies 13
  • Views 1.6k
yes they do. Only slightly different. I believe spare parts such as oil seals are very hard to get hold of for them.
Not at all entertaining then when the oil seals go!
Are they not just metric O rings? Even if not,I'm sure you could use one suitably sized. Any hardware store sells them for pennies.
I work with hydraulics,and though i use alot of custom profiles and compounds,i also use alot of standard metric O rings for far higher pressure than a charger will need - eight bar is the most a G40 oil pump is gonna push,you could hold that with an elastic band.
the seals see some pretty high shock loads in terms of sudden oil pressure and air pressure changes and pretty high RPMs. They aren't just basic o-rings. A lot of mk2 g40 owners have swapped their original g-laders for mk3 ones because of lack of spare parts. I dare say suitable replacements will exist but people obviously think it's just easier to swap the charger than investigate replacement seals.
Well for anyone needing any type and size of oil seal,bearings,sprocket/belt (custom charger drives),fitting etc etc..
http://www.brammer.biz
They're nothing to do with us,just a supplier.
The charger i got hold of had barely used seals in it, i found a guy on german ebay who had a set of mk2 charger seals but i decided against buying spares, perhaps on reflection i should have done!
They didn't look much different to me, but i'm sure there may be some tiny difference, the other thing is there are two types of mk2 charger, the one i have fitted is a newer type of a later press car, but i also have an earlier one with a damaged scroll, this has a seperate collar with an O-ring that sits between the two sides of the charger where the inlet pipe pops on. I wonder whether the later type mk2 charger has the same seals?
Mystery...
if its the mk2 charger you had from me tom its not a press one it came from a vw training school
and have the dvla now been notified about the reshell now and all paperwork up to scratch?
luke
yes mate, it's all legitimate now, i wrote them a letter and they said as long as it was a shell i bought and have had proof of ownership it's not a matter they'd be willing to look into. Just shows the dvla know when and when not to call a car a ringer, i came across the solution when chatting to someone who re-shelled a lightweight carrera rs porsche into a second hand shell.
ah i thought you said it was from a press car, my bad
Edited by Tom Garrett
good I'm glad to hear it just wish youd done that before when i had it :-( good luck with the sale anyway.
luke
i see the ebay ad mentions mods to the shell when you swaped bits over
what bits differ on a g40 compared to a std one ? did vw just cut out a piece of the front panel like that?
Bit of a grey area,the originality thing. A car has to retain a certain percentage of its original parts to keep its ID,but its often taken with a pinch of salt.
There are thousands of cars out there with non-original engines in non-original bodies,custom interiors,etc etc and the owners are clutching the original plates by a handful of parts down to the wiper motor etc.
Of re-shells/builds I've known on existing plates,nothing more was done than a note in the service history book,and the shells carried both chassis numbers. Engine numbers,displacements,and colours excepted. And the odd axle addition (friend of a friend did a six wheel Metro).
Not knowing what best to do myself,i just kept the plate of the chosen shell on both my own occasions.
If you like the old plate that much,keep it - its only an 80 quid fee to transfer it.
The front panel has cutouts for the intercooler to breath low down, also there is a cross member behind the front panel which had to be changed to accomodate the boost pipe coming from the supercharger. A hole cut in the inner wing, where another boost pipe goes through it. also i had to make some small modifications to the body for the handbrake mechanism which was different on the g40, but i think that was down to age and not because it was g40 specific.
Getting back on topic, the normal oil seals can be used, but are infact inferior to Goetze and QPM. Standard industrial seals will work on standard pulleys, but not when running more boost. As Hayesey said, it has got to do with heat, rpm, oil pressure, boost pressure and acceleration.
Trust me, I have tried industrial spec seals ;)
As for the seals, they are the same in Mk 2 and Mk 3 Polos, which again differs from G60 seals. G60 seals work fine in G40's
Edited by G40NUT
