Rusty Petrol Tank Neck
Got a mk2 saloon and it is a bit of a rust bucket to be honest but I'm getting there slowly. The only bit that bothers me is the neck on the petrol tank. If i fill up to the brim it will leak, even about £25 will leave a little pool behind but it doesnt seem to drip out, just sort of seap. I want a cheap fix because this is only my daily runner.Figured I had possibly 3 options.....
If I was to coat it in Tetroseal underseal (the tar like stuff) would this plug any pin holes enough to stop the leak?
Could I coat it in fibreglass or is this not advisable near fuel?
Or is my only sensible option to get a new one welded in :paranoid:
First option worked for me, you can try it and see if it works then if not get a new tank.
That was my plan but I managed to fill the leak and its been 2 weeks and bone dry, so.....
I remember patching a rust hole on the filler neck with steel putty(available from most motor factors) amazing stuff that is fuel resistant and piss easy to use. Might not pass a m.o.t but I no probs for months..
any solvent based underseal will soften and let the fuel through it, expensive paints like por15 may work
fibre glass is probably the best bodge ...clean it up really well first
tbh id just look for a cleaner tank , alot of polos have had em so theres a good chance of finding one at a scrap yard
Cheers for all your help, I was thinking of that steel putty cos Iv got some but cant find exactly where the leak is coming from and they are proper akward to get at! I'll keep my eyes peeled for a new tank me thinks and in the mean time...bodge job here I come :-D
new tank is about about £50 from fueltanksdirect (google it).
