Making A Trailer Out Of A Polo
My first '96 Mk.4 6n 1.9D CL in red recently had diesel pump probs that I couldn't resolve, so I got another identical one (green) to replace it.
But that had big problems with a broken dual mass flywheel tearing chunks out the gearbox bellhousing, so Red sacrificed its gearbox, flywheel and a few other bits for Green which at least runs well now.
Polo 1:
Polo 2:
Anyway, I'm left with the red one, semi-broken for spares with a decent condition bodyshell and rear running gear.
What I fancy doing if I get bored over the winter is chopping it and building a wee trailer from the back half.
Maybe cut it so the front half of the roof can be bent down at an angle from halfway point to form the top front piece and use the bonnet metal to build up from the floorpan. Try to give it a reasonably streamlined shape sort of thing.
I'd imagine the stock rear hatch would be big enough for access so the heavy rear doors could be removed and the outer skins used to weld back to the body, replacing the glass with steel panels like a van, but keeping the body lines smooth.
Anyone attempted this kinda thing?
I've seen a few trailers made from the back ends of Golfs, Beetles, and even a Karmann Ghia, but never a Polo. :unibrow:
Edited by seamonsta
  • Views 960
I'm sure I've seen pics of someone with 6n trailer on here
a white mk3 has done it aswell
Cheers man - that's what I was hoping to hear!
Anything to give me a visual of how it might turn out would help - I'm not trying to be unique here... :thumbsup:
theres a picture or 2 if i can remember in chrispys thread of the clubpolo show 08 of the mk3
Just remember unless you are planning on having a braked trailer then it's maximum laden weight is upto 750kg but you are limited to 50% of the unladen weight of the tow car so about 515kg.
Aye - braked would be the way to go.
I'd leave the complete rear running gear and hook the handbrake cables up to a load adjusted spring hitch.
500kg is plenty enough weight limit back there - I'd use it more for bulky stuff.
Edited by seamonsta
