Weight Saving
HI , got a mk 3 and allthough is light I'm looking to grind away some of my weight , where can i grind and not have probz ?? inner back quaters ?? boot ? boot lid ? I'm looking to drop 20 kgs to improve my power to weight ratio , on the verge of going on a diet i wnt the weight down in mi car tht much , thanks
  • Replies 21
  • Views 2.5k
I wouldn't grind metal away from the car. Must be there for a reason after all.
What about changing the windows for plastic replacements and fibreglass panels?
I heard typing properly saves 150 kg.
pmsl hahaha
well I'm going to make some perspex rear windows and tailgate glass
take carpets out + spare wheal headlineing doorcards gloveboz sith all its junk passanger seat ne thing that is not needed :lol:
i use this car as a daily driver so plastic windows arnt realy a optioin , and forgive my spellin boys i have problems
I think you save about 5kg in a bready just from replacing the rear side windows with polycarbonate. Same again for the fronts. Definitely lose the spare wheel for another few kg. Charcoal cylinder in the engine bay's good for nearly another kilo.
Daily driver means you can't strip the interior then? What kind of use will it get - could you take out the rear bench, boot carpet and parcel shelf?
you'll struggle to drop 20kg without losing glass or seats dude, shaving 20k of metal off the car isnt going to do much as they're already tin cans as is!
Polycarb side windows and losing spare wheel + interior will see a good 13-15kg, if you want to save any more you're going to have to strip everything down, lose soundproofing and just drive in you are birthday suit I'm afraid!
spare is in atm might get a spacesaver so can stil limp home if needs be , shelf is modified to be lighter so will the big metal sheet on the rear seats soon , carpets nuffin n need front 2 seats , i need extra power but got little money ,may disconect the water suply around my inlet to get cooler air
tell you what dont carry pasengers if possible :lol: no seriously take as much out as you can even the sound dedening stuff even under the bonnet there must be things that can be removed.
dont worry on spelling I'm not much good at it my self
oh i dnt worry fuk ani 1 hu thinks they r beta thn me cuz they can spell , i have already got 7 kgs off the doors alone startin on behind the dash tomorow ist workin at mthe lites by me 2 nyt a sabb 93 and a audi a5 were racin n i sliped between thm at lites wen the changed n cudnt catch me
mines a dailey driver still has perspex rear windows my spelling isent mutch better i am afraid pepole
fibreglass boniet
rearor disc conversion is lighter than the rear drums
where can u get a lighter bonnet could u cut the underside of you are bonnet ?
i went stock cars the other week there was loads of novas corsas fistas with fibreglass bonits theres a place in credtion that make carbon fibre pannles and fibreglass at a £££ tho
i might seperate my bonnet skin and take out the centre n put a nife in my grill 2 stab the next m8 hu sits on mi bonnet lol
Use firefox instead of internet explorer. It has a built in spell check, although it has American spelling.
thanks !!
how much weight u got as underseal ??
Asinine syntax appears to be a lour garrison right across the web,rightfully glowered upon by most here.
There should be an ardency to festoon your post in a comprehensive array of passion,yet to blazon your picture expeditiously too.
It appears too onerous though,and ashen trite now exemplifies a mediocre normality - itself at risk from a new low in the world of expression. Correct english shouldn't be abstruce,but communications at all are becoming so,in ascendance. Here not just abound mordancy,i assure you.
Incidentally,my polycarbonate windows bear no impact on the car's function as a daily driver - invisible in semblance.
I agree
:retard:
I chiseled out all of the sound proofing from the floor of my GTi-R and weighed it and it came to 10kg! I have also stripped the wiring looms down and got about 5-6kg from them so far, also got a carbon kevlar bonnet and GRP doors and tailgate.
It all depends how keen you are really tbh and what you will put up with, my car was deafening with just the carpets and rear seat out.
Thats the wiring i've binned.
New loom to the rear of the car.
The interior at present.
Matt
I drilled holes in my tyres to save a bit of weight. The rubber weighs a ton!
